Dimensioning a feature in multiview or single view
In a part that i have designed there are 4 chamfers. In a third angle drawing, i can only see 2 of the chamfers in the top view and the other two in the front view.
Can i use a repeated dimension ( 4X 10 X 45 Degree symbol) in one of the view? Or should i dimension the chamfer in each view?
thank you in advance for your help.
RE: Dimensioning a feature in multiview or single view
If it's a complex or otherwise potentially confusing drawing that's when you'll want to be more explicit.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
