ASCE7-10 section5 chapter15 Seismic Design for non building structures
I have been looking thru the ASCE library for a copy of the referenced subject. None was listed, so is chapter 15 part of a greater volume of work that has to be purchased? Since the portion of chapter 15 that I am interested deals with propane and ammonia tanks stored outside, will other sections of ASCE7-10 be required in that purchase?
RE: ASCE7-10 section5 chapter15 Seismic Design for non building structures
I was unaware that one could purchase the ASCE 7 in a chapter by chapter manner. I've only ever seen it available for purchase as a complete document.
Like available here
Now then, depending on what exactly you need from chapter 15, you may be pointed to other external references that cover some of those seismic design issues.
