Beam section offset
Beam section offset
How can the beam section be placed inside of the geometry? I need the beam elements shown in the image to be only on the inside of the body. Is there a offset command, it do not matter if the solution is in the interface or py format.
Thanks!
Thanks!
RE: Beam section offset
You should think about two other options:
1. If you have geometry or elements edges at the location where the beam should be, then you can use Stringer modeling. That is a beam, that shares nodes with the shell or solid elements. See A/CAE Manual 36. Skin and stringer reinforcements
2. You can also use embedded elements technique to include the behavior of the beam into the solids. See Users Manual 35.4.1 Embedded elements and A/CAE Manual 15.15.8 Defining embedded region constraints
