when does a finite element analysis become labeled "nonlinear"
I tend to think of a nonlinear finite element analysis as "nonlinear" if it is a time-history analysis or dynamic analysis. I am a structural plan reviewer for a west-coast jurisdiction. I am the only engineer. The plans I'm reviewing are of a 2nd order magnified moment analysis of columns and braces - aka 2nd order analysis with P-delta effects (the old way of doing 2nd order). Is this considered "nonlinear" I believe the engineer is basically doing a linear elastic analysis and then applying the magnification. I know it's splitting hairs, but it stuck out to me because of its repetitive use of terminology.
Thanks anyone who can respond kindly.
OUe
OUe
RE: when does a finite element analysis become labeled "nonlinear"
Static analyses can certainly be non-linear, both for geometric and material property effects, and dynamic analyses can be linear.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Dynamic analysis doesn't have to be nonlinear. Doing a nonlinear dynamic analysis is much less common in my experience than a linear one.
1. Nonlinear boundary conditions: Usually a change in the contact situation; Friction
2. Nonlinear material
3. Geometric nonlinearity: Large strains; large rotations; preloading effects; load stiffening effects; update of load directions; etc.
The FEA guys in this forum may scoff at the nonlinear analysis used by building structural engineers. Commonly used building analysis programs with nonlinear capabilities use non-linear hinges or fibers that the user defines. The model still includes a bunch of non-linear sticks (frame elements) and shells. For building analysis techniques, the "Structural engineering other technical topics" forum would receive more responses.
