Dissociated dimensions
Using NX 10.0.3.5.
I made a change to an existing drawing yesterday, and before I started, I noticed all the dimensions were dissociated. So, I reassociated all the dimension to the correct solid edges. However, when I opened up the drawing this morning all the dimensions were dissociated again.
Anybody know what's causing this? Thanks.
RE: Dissociated dimensions
Also, are you working Mastermodel? In a teamcenter environment?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
"Also, are you working Mastermodel? In a teamcenter environment?".....Yes for both.
I noticed that the dimensions don't appear dissociated until after I update the views. For some reason, each time I open the drawing file the views are out-of-date which is not an unheard-of red herring.
That's why the views are still correct (associative dimension) until you update them. Then the 3D model is "removed" from the views and dimension get retained.
Is it possible for you to share your Drawing and Item? (Export assembly from Teamcenter)
NX9 / TC10.1.2
-Dave
NX 9, Teamcenter 10
NX9 / TC10.1.2
