CATIA VBA Macro for automatic fillets on vertical edges of the Pad
Hi Everyone!
I was wondering if there exists already the code for automatic fillet generation on first pad under specific body...
I'm working a lot with "structurized" parts (with the use of assembly feature) where first body is semi-finished product :) then all the milling and drilling is devided on multiple assemblies. The trick is that first pad under first body must have rounded edges (since its part made of steel plate, which is burned out).
I've found something under CATIA docu's -> look here. But it takes care of 4 edges,and in my case edges count my vary... ponder
If there's already a solution for that, please point me.
Greets
Lucas
RE: CATIA VBA Macro for automatic fillets on vertical edges of the Pad
you could use the script from the online doc and adapt it.
if you look at the script you will see it does find an edge by the 2 faces that define the edge:
"REdge:(
....Edge:(
........Face:(Brp:(Pad.1;0:(Brp:(Sketch.1;4)));None:());
........Face:(Brp:(Pad.1;0:(Brp:(Sketch.1;1)));None:());
........None:(Limits1:();
........Limits2:()
you see also the face is define by the ReportName of the sketch element:
knowing this you could cycle through each edge in the sketch, find one next to it and define all references for the fillet.
usually, two continuous sketch elements do share a common point: line1 uses point1 & point2, line2 uses point2 & point3 but it's not always the case and you could have line1 uses point1 & point2, line2 uses point3 & point4 with point2 and point3 on top of each other (or distance is bellow CATIA tolerance).
Sketch geometry do have StartPoint and EndPoint.
You now have everything you need, have fun. Please post your result.
Eric N.
I have done simillar. Use find command to find every edge of the pad. Then put it in a array. After this add every item from the array to fillet command.
Tiago Figueiredo
Tooling Engineer
Try something similar to this. I have created for chamfers.
CODE --> vb.net
Dim body1 As Body
        body1 = bodies1.Item("Block")
Part1.InWorkObject = body1
        Dim shapes1 As Shapes
        shapes1 = body1.Shapes
pad1 = shapes1.Item("Main block")
        selection1.clear
        selection1.add(pad1)
        selection1.Search("Topology.CGMEdge,sel")
        Dim Num_arestas1 = selection1.count
        Dim arestas_ref(Num_arestas1)
        For i = 1 To Num_arestas1
            arestas_ref(i) = selection1.item(i).reference
        Next
        selection1.clear
        Dim chamfer1 As Chamfer
        Dim shapeFactory1 As ShapeFactory
        shapeFactory1 = Part1.ShapeFactory
        Dim reference1 As Reference
        reference1 = Part1.CreateReferenceFromName("")
        chamfer1 = shapeFactory1.AddNewChamfer(reference1, catTangencyChamfer, catLengthAngleChamfer, catNoReverseChamfer, 3.0, 45.0#)
        chamfer1.Name = "Corner Chamfer"
            chamfer1.AddElementToChamfer(arestas_ref(i))
        Next
Tiago Figueiredo
Tooling Engineer
