Planetary gears set with compound planet gear
Hi all,
I want to model planetary gearset having compound planet gear i.e. One gear of compound planet is meshing with ring gear and the other gear meshing with sun gear. Does anyone knows how to model this scenario using KISSsoft. The current planetary module avialable in KISSsoft allows only simple planet gear modeling.
Sachin
RE: Planetary gears set with compound planet gear
Take a look at KISSsys.
