Interesting Ground Vibration Measurements
I got a guy to take some ground measurements for me at a site where a piece of machinery is producing unacceptable vibrations in nearby structures......and one thing that is jumping out at me is the fact the vibration amplitudes (of the ground) are actually higher within several feet away from the source than (at the top of concrete) at the source.
Has anyone else run into something like this? I am use to the vibrations at the source being higher than anything away from it (even at a short distance). I suspect some of this may be because some of the soils in the upper layer (at the site) are fairly loose.
RE: Interesting Ground Vibration Measurements
https://earthquake.usgs.gov/regional/nca/soiltype/
Good point Ron.
