Rename Aseembly/Part from Drawing
Is there a macro that would let me rename the part or assembly I am drafting from the drawing workbench?
I am working with a large assembly and have to rename details and assemblies based on which page they reside on.
RE: Rename Aseembly/Part from Drawing
Jenia Ladkov
So, I am unable to assign a number to it until i know which page it will be detailed on.
If the view is moved to another sheet, the part number would change.
For example:
Details on sheet 2 would look like:
-201, -202, -203, -210, and -265.
Details on sheet 3 would look like:
-301, -302, -303, -310, and -365.
not impossible to do I guess as the link Drawing -> Part will not be associative, but made by script.
You will eventually face a problem when a view is moved and the part is not renamed at the same time.
Also changing the view from one sheet to another might trigger release process if the 3D is already released and you want to change its name...
Anyway. in order to be able to know what part is used for a view, we'll need to understand how your create the view.
is the view link with the part? or with the product, using a scene? or using modifylink function? Is the view linked or isolated?
