Detail view problem in NX 7.5
Hey, I'm using NX 7.5 and I have a rather weird problem with a Detail view.
I'm using circular type detail views and most of them seem to be working fine, but every forth or fifth detail view acts weird.
First of all, I choose the view boundary that I want to show in the circular view and after placing the scaled up view the NX progresses it and snaps the boundary into a random place on the sheet. The scaled up detail then becomes unselectable and unmovable, meaning I can only get rid of it with CTRL+Z (Cannot delet it as I can't even select it). Neither the scaled up detail or the circular boundary can be selected or moved. The problem is that whenever the boundary snaps to a random place, the scaled up view also shows this random place, making the detail view pointless.
It is not a huge problem as I can replace the broken circular views with rectangular ones (they seems to work just fine) and carry on with circular views from there, however it does not look good visually if there are rectangular and circular detail views mixed up on the drawing.
If anyone has had the same problem or knows what causes it I'd appreciate it if you could share your tips.
Thanks!
Thanks!
RE: Detail view problem in NX 7.5
I would suggest contacting Gtac and ask them.
Concerning the deleting of such a problem view, you should be able to delete them from the part navigator.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
