Please respond if you have comments
Please respond if you have comments: Site is less than 1/2 ac. on a corner lot which has been used for the past 28 years as a used car sales lot at the intersection of two public roads. The site before demolition consisted of two buildings, concrete driveways & sidewalks, an asphalt car display area, and the balance of being a compacted gravel parking. Slope averages 2% and runoff is sheet flow toward adjacent properties. New owner wants to keep the site as a used car lot, but improve with a new building. The parking lot must be fully paved with concrete curbing, and landscaping on all perimeters in accordance with City regulations. Using NRCS Curve Numbers we provided a layout that met the Post-Dev. runoff did not exceed the Pre-Dev. runoff. After submitting the plan & drainage data the City disputed the Pre-Dev. calculations. We revised the plan to reduce the amount of pavement and thus the drainage even more. The city has now said we must evaluate pre-development drainage and evaluate the site ignoring the compacted gravel areas as such and using residential lot with grass numbers instead. Has anyone else run into this and how it was addressed? The owner is talking legal action. I'm not too sure he's wrong. Thanks.
RE: Please respond if you have comments
If the site is contributing to downstream flooding via the percentage of impervious, the jurisdiction will pursue more on-site storage to mitigate the downstream flow.
This means going back to the original topo, if known, plus the original native vegetation prior to development. Some of the items are usually negotiable, but not the onsite storage.
Mike McCann, PE, SE (WA)
In summary, while your Client may have a leg to stand on in court, as an engineer, you likely will be fighting an uphill battle with the review agency.
One reason being that the municipal stormwater system is usually the downstream property. The stormwater system is not only the manholes and culverts, but also the receiving open channels, creeks and rivers. The municipality probably has an MS4 permit which limits pollutant discharges in stormwater and mandates that municipalities take measures to reduce pollutants. Probably one of the largest sources of stormwater pollutant in urbanized areas is sediment loading from stream bank erosion, stream bank erosion caused by stormwater discharges in excess of the natural stream-forming discharge. 28 years ago when the lot was built, the discharge in the receiving stream increased, and stream bank erosion began. Must urban and suburban municipalities want to claim that they are actively working to reduce pollutant loading, not just keeping the status quo. One way to do that is to have redevelopers actually improve drainage and reduce discharge, not just keep it the same.
Rules might be different in more rural areas where stream bank erosion and sediment loading is not the primary pollutant of concern.
Seems to meet that criteria.
water, wind, sunlight and everything else might also meet that criteria
also, who determines what is an "undesired effect"?
Here, I grabbed the Civil Engineering Reference Manual (10th ed.) as it is a basic engineering text. Page 32-2, A pollutant is a material or substance that is accidentally or intentionally introduced to the environment in a quantity that exceeds what occurs naturally.
Does that definition better suit you?
actually the second definition is no better than the first. but lets stay on topic here. I'm not saying that stream bank erosion is necessarily good or bad, but calling it pollution is still a stretch
I've seen some municipalities give you credit for some of the existing impervious if it is a redevelopment job.
Just in my region, I've seen the following approaches used:
1) pre-dev = forested no matter the current ground cover
2) pre-dev = grassed no matter the current ground cover
3) pre-dev = current ground cover
4) pre-dev = current ground cover but provide a 30% reduction of post-dev flow rate
5) pre-dev = forested and provide a 10% reduction of post-dev flow rate
6) pre-dev = current ground cover but provide a percentage reduction of post-dev flow rate equal to half of the impervious ratio of the current site (no kidding, this is a real reg)
7) pre-dev doesn't matter, match a fixed unit flow rate per area of watershed for the design storm
8) pre-dev = current ground cover, but run your 1,2,5,10,25,50 year storms, and then your post-dev 2,5,10,25,50,100 year storms have to match those allowable discharges. Basically slide the events by one notch and match those.
9) I even saw one that required us to develop our predev allowable discharges with rational method and our proposed discharges with SCS method. That was a head scratcher.
Then you run into TC issues. Ten acre parking lot today, treat it as wooded, do you give it a wooded TC or its current TC? And how would you know what the wooded TC was given that the site has been graded?
Then you run into historic storage issues on top of that. If the site has a pond today, do you match the releases of the pond? Or do you have to pretend the site is wooded going into the pond? What if there are depression zones on the site, do you route them as zero discharge ponds to model predevelopment runoff attenuation?
Etc.
There's no one way to do this. That's what makes civil engineering fun.
If I were tasked with writing a regulation for a local municipality, I'd pick a soil type, pick a land cover, pick a TC, run an analysis for one acre of watershed, and then develop an allowable discharge per acre of site. Strip the modeling requirement out entirely and just hold engineers to an allowable discharge per existing basin area. Make it simple and inarguable. As sad as it is to say though, the weirder the regulations get, the more job security there is for engineers who know how to navigate them. So I guess there's a strange kind of silver lining to the whole deal.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
