CYCLE THROUGH CAPTURE SELECTION AND DISPLAY EACH CAPTURE ONE BY ONE FOR PRINTING
Hello Ferdo and Others
I am trying to cycle through Captures, one by one, for printing the screens. See partial VBA code at bottom and attached image for more info.
However, when running the code to cycle through the captures, there are small "CATIA V5" windows appeared as seen on attached image. If I remove the "MsgBox CurCapture.DisplayCapture" statement, captures are not able to cycle and displayed for printing.
1) How can I still cycle and display the captures, one by one for printing but without the small "CATIA V5" windows?
Also, I want to obtain the capture's name/value (ex: PART INFORMATION) displayed just before the actual screen appeared (to confirm the right screen displaying before printing). I look at property "Name" of Captures but it won't work. How could I obtain captures' name (or value) for displaying?
Any suggestion or example code?
Thank you again
Quin
============================== VBA CODE =====================
' Set the first annotation set
Dim AnnoSet1 As AnnotationSet
Set AnnoSet1 = oAnnotationSets.Item(1)
' Get the number of captures in "annotSet1" above
Dim NumberCaptures As Integer
NumberCaptures = AnnoSet1.Captures.Count
MsgBox "Number of annotation sets is: " & oAnnotationSets.Count & " and number of captures is: " & NumberCaptures
' Loop through capture collection
Dim j As Integer
For j = 1 To NumberCaptures
' Display the current capture
Set CurCapture = AnnoSet1.Captures.Item(j)
Next
Thank you again
Quin
Dim j As Integer
Next
RE: CYCLE THROUGH CAPTURE SELECTION AND DISPLAY EACH CAPTURE ONE BY ONE FOR PRINTING
CODE --> code
MsgBox CurCapture.DisplayCapturedoes the small CATIA V5 window... remove that function and voila
