automation design call calculation accuracy
Which design steel detailing software to give more accurate design calculations and detailing output and structure input to model
RE: automation design call calculation accuracy
By using the word "accurate", are you meaning "realistic"? I think that all of the major software analysis packages are "accurate" (i.e.: precise). If you are rather asking about realistic answers, then you only get out of a model what you put into it. Better modeling with better assumptions made by you will provide better, and more realistic, answers. Use the software package that you like, and feel most comfortable with, and use good judgement in making the assumptions required by any good model, and you will get realistic answers in return.
Dave
Thaidavid
the software is as good and as bad as the engineer who is sitting in front of the screen :)
best regards
Klaus
Thanks klaus but any have idea about SDS2 and tekla, from fabrication and detailing point of view
are you talking about calculation or design or drawing or....
You should precise your question
An answer can never be better than the question :)
best regards
Klaus
