pump discharge pressure
Hello All:
need your help..
I want to read the differential pressure across the pump accurately. see the attached sketch
There is a electric heater on the discharge of the pump
I have a suction gauge very close to the pump and the discharge gauge tap is located on the heater outlet roughly about 8 ft from the pump discharge flange. From the tap there is a 1/4" coiled tubing brought down and the gauge is located roughly on the same elevation as the discharge flange
Currently the discharge pressure is reading 125 psig
question: what is the actual discharge pressure. is it the same as the gauge is reading minus the heater pressure drop and minus the pressure drop from the pump up to the pressure tap. I say this, because the gauge is located down and liquid head is acting on it making it read the pressure at that elevation
Please comment
Kind regards,
Araza
need your help..
Please comment
Kind regards,
Araza
Asif Raza
RE: pump discharge pressure
Thanks..
Just so I'm perfectly clear. The heater pressure drop is 1 psig and the gauge is currently reading 125 psig
So the true discharge pressure near the pump discharge flange would be 125+1 = 126 psig
Araza
Asif Raza
