Temperature chage rate!
Is there any way for calculating temperature changing rate in a reactor?
Would be grateful for getting any help.
Many Thanks.
Many Thanks.
RE: Temperature chage rate!
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
It can be done by your mentioned procedure if I have enough data.
If I want to find it by using heat of reaction (exothermic reaction) for a certain period of time would it be possible to get temperature change?
Thanks.
Good luck,
Latexman
