Creation of a weld defect to qualify a procedure
We have recently been asked to qualify a repair procedure and we are struggling with one aspect.
The customer specifically asked that we create a weld with a defect in it, then repair the weld to qualify the procedure. What we are struggling with is how to create the defect.
The weld itself will be in a 1 1/2 inch thick plate of SA-516-70 and the joint is 36 inches long. They want the defect to be at the mid point of the weld so 3/4 inches deep.
We have a number of opinions on how to do this but no one is certain that it will really work. While not required from the customer I am going to have the joint RT'd to show the defect and not everyone is certain that the different ideas will show. We have talked about placing some slag in the joint and welding over it, placing a tig rod in or using a SS filler rod.
An inspector will be present to witness what we are doing and will confirm that a defect was present based on what we do regardless of what the RT shows but my curiosity on how to do this want to know.
Does anyone have any experience with this that can offer some advise or ideas? We have plenty of welds that fail that we are not trying to but now that we are trying to make a defect we can't agree on what to do.
RE: Creation of a weld defect to qualify a procedure
Best regards - Al
The goal here is to produce incomplete fusion against the groove face on one side of the groove. Since GMAW-S produces low heat input, it does fuse well through oxides and it doesn’t penetrate deep crevices (ropey weld beads) between weld beads. So, use that to your advantage. Heat one groove face to red heat to cause oxidation. A piece of metal bar placed against the opposite groove face will prevent it from being heated and oxidizing. Next deposit stringer weld beads against the unoxidized groove face and deposit successive beads side by side. When the layer is almost complete, slow the wire feed speed and reduce the travel speed so the last stringer bead is bigger than all the previous beads, but do not direct the arc against the oxidized groove face. The last weld bead should not fuse to the groove face and because the travel speed is slow, it should produce a deep crevice between the weld bead and the groove face. Deposit the next layer using the original parameters and deposit a second layer over the initial layer deposited using GMAW-S. Now switch back to the original welding process, either FCAW or SAW, whatever you typical would use and complete the weld.
You should have incomplete fusion against the groove face on the one side. The orientation of the X-ray will have to be oriented parallel to the groove face to optimize the probability of detecting the incomplete fusion. You could also verify the incomplete fusion using shear wave UT with the shear wave oriented perpendicular to the groove face.
Let us know how it works out.
Best regards - Al
We did some using pieces of ceramic rod, but it was too difficult to get the size we wanted.
Regardless, you'll have a weld defect there.
http://www.fusionpoint.be
http://be.linkedin.com/in/fusionpoint
See if this material help can bring some help
Whether RT with detect a discontinuity or not is dependent on the orientation of the discontinuity relative to the location of the source. If the discontinuity is perpendicular to the "beam" of ionizing radiation, the discontinuity may be missed if it does not represent a change in thickness or density. If the orientation of the discontinuity is parallel to the ionizing radiation, the probability of detection is greater.
Simply put, RT is unlikely to differentiate between two 1/2 inch thick plates placed on top of each other and a 1 inch thick plate. Thus laminations are unlikely to be detected using RT. However, two 1 inch square bars placed side by side and a 2 inch x 1 inch thick bar placed side beside the two 1 inch bars is easy to differentiate. Thus cracks oriented parallel to the beam of ionizing radiation is easily detected.
The attached sketches probably does a better job of explaining the subject.
Best regards - Al
Best regards - Al
Then weld over the tungsten "inclusions". Guaranteed to show up in an RT film.
Just a note about using the copper implant; it doesn't take much copper to cause cracks in carbon or austenitic stainless steel. I usually use a "whisker" of copper wire from a welding lead. Only a 1/4-inch length is needed for a single pass weld. The cracks are intergranular and run in multiple directions. While they are useful in providing something for the student to see, they are not representative of either a transverse or longitudinal crack.
Free machining steels containing sulfur, selenium, or even lead, are usually pretty good materials for longitudinal cracks along the centerline of the weld.
Good samples for training purposes can often be found in the scrap bin in a welding school.
Best regards - Al
