Calculating RPM of electric motor
Good evening
I would like to calculate the RPM of my electric motor. The motor will be mounted on a car and will have to move a mass of approximately 500g. I know that the RPM at 1.5V with no load is 4242 RPM., current of 0.042 A. At maximum efficiency I have 3296 RPM, 0.151 A, Torque 6.8 g-cm, 0.345 W of output Power. Does anybody know how to calculate the required RPM? many thanks guys. :)
RE: Calculating RPM of electric motor
Dan - Owner
http://www.Hi-TecDesigns.com
Then either do some tests oo find the torque speed curve for your motor. Simple.
notice too your units are all over the map ... torque in "g.cm" ?? need Nm, rpm to sec^-1, then you can check your power in Watts.
I 2nd MacGyverS2000 ...
