Reasons for not using perforated impingement plate - API 660
Hello
API-660, clause 7.6.4.6 states that 'perforated impingement plate baffles shall not be used'. Can anyone throw some light on the logic behind this prohibition? Any input would be appreciated. Thanks.
RE: Reasons for not using perforated impingement plate - API 660
please don't double post
The perforations slow the velocities coming off the plate. It is not desirable to slow this velocity going toward the tubesheet. Slowing this velocity can create a stagnant area where there can be corrosion and fouling.
Report
EdStainless - i was not sure whether the pressure vessel foum would be the right one / whether i could get more expertise here. Thats the reason for duplicating. any trouble is regretted
srFish - Thanks much for this clarification. I do find it useful and infact was also reading a paper on the same topic. Could you please clarify a bit more on the 'stagnant area'.
The stagnant area is the area from the forward front of the impingement plate and the tubesheet.
I called it an area but it is actually more of a volume.
Thanks again. I got your point.
Unfortunately even after being prohibited by API-660, many users are still using perforated impingement plates in disguise of distributor (to achieve thermal efficiency). Any comments on this practice (of-course I am talking about those equipments where the design should comply to API 660 contractually)?
