ASME Sect 8 Vessel
ASME Sect 8 Vessel
Does ASME Sect 8 Tell you to have a smooth Ground flush finish on the inside Weld of the Nozzle for a pressure Vessel? or is it something that I need to specifically tell my vendor, if I require it ?.
If ASME tells you, can I please have the Section number.
Thank You
Thank You
RE: ASME Sect 8 Vessel
1) If the pressure vessel is stainless steel and hygienic design, obviously inside surface shall be smooth and polished, ….and more good engineering practice other than ASME VIII
2) UHT-84 WELD FINISH
The requirements of UW-35(a) and UW-51(b) shall be
met except that for SA-517 material the maximum weld
reinforcement shall not exceed 10% of the plate thickness
or 1/8 in. (3.0 mm), whichever is less. The edge of the weld
deposits shall merge smoothly into the base metal without
undercuts or abrupt transitions; this requirement
shall apply to fillet and groove welds as well as to butt
welds.
r6155
Mike
