Element deletion - Hyperelastic Material
I am running an Explicit analysis of a hyperelastic material using the VUMULLINS subroutine. I am trying to use element deletion for failed elements, but it is not working. I assume this is related to one of the warnings I am getting:
"Output request sdeg is not available for the material for element type c3d10m"
(note: I have tried different element types, but get the same warning for those). Is there some setting I should be changing to be able to get the SDEG output? Do I need to change the VUMULLINS subroutine from its original form in the User Subroutine Manual (http://129.97.46.200:2080/v6.14/books/sub/default....)?
