Difference betwen ellipsoidal and torispherical heads
Difference between ellipsoidal and torispherical heads
What is the difference between ellipsoidal and torispherical heads? since the point of view to utilization, fabrication, membrane stress distribution, others.
For example, in my case I have Pi = 1,7 MPa, nitrogen gas to -45 C, Di = 1.800 mm, SA-240 316L.
1 Ellipsoidal 2:1, then L = 0,9Di and r = 0,17Di
S = 149 MPa @ -45C
E = 1,0
K = 1,0 (Table 1-4.1)
t = PxDixK/(2xSxE - 0,2xP) = 10,2 mm
2 Torispherical wiht L = 0,9Di and r = 0,17Di (identical geometry to Ellipsoidal 2:1)
S = 138 MPa (see UG-32 d)
E = 1,0
M = 1/4x(3 + (L/r)^0,5) = 1,33
t = PxLxM/(2xSxE - 0,2xP) = 13,2 mm
Both geometries are identical, but the equations, procedures and S (admisible strees in tension) are differents, but even worse the minimal required thickness are differents.
Can someone help me with this?
In this case both heads are ellipsoidals or both torispherical or what?
If I ask to "vessel maker" Ellipsoidal or torispherical, like this case with identical geometry, what is the difference and why does the ASME VIII D1 to deliver different results for t to identical geometry?
S = 149 MPa @ -45C
E = 1,0
E = 1,0
RE: Difference betwen ellipsoidal and torispherical heads
Note that a 90-17 torispherical head is NOT identical to a 2:1 ellipsoidal head. That equivalence is completely bunk. The two heads look somewhat the same, but are quite different.
Stay tuned. Once the draft paper goes through peer-review, and settles into its final state, then I will be able to discuss further. That will also drive the Code change - hopefully for the 2019 Edition (the window for making changes to the 2017 Edition having closed around December of last year).
How can they be "quite different" if they're made from the same material and the geometry is virtually identical? In any case I don't think head manufacturers form actual ellipsoids, they just use torispherical approximations.
-Christine
The overall dimensions may be similar, but they are definitely not identical nor equivalent.
Our (the paper) survey of North American head manufacturers showed that half made true ellipsoidal heads.
This post is timely, I'll watch to see how things change in the code...
I have had very luck with your answers and comments because I see that I have the best of two worlds, for a side a guy with the knowledgement of norm from inside (he says that the norm has a problem in this topic and should change on near future) and on the other side guys with comments from the manufacturing industry of vessels (market, reliability of industry, fabrication problem, others)...great !!
I live in Chile and here it's even harder to find vessel manufacturers that can to make really ellipsoidal heads, so it is better in my situation and case, make a design for torispherical head and to be conservative.
Trevor, do you have any paper or similar that to explain this problem between Ellipsoidal 2:1 and torispherical 90-17?
Cheers
