Need special formula for data entry
please find the below image and do the needful to create special formula.
Thanks in advance.
Ravi
RE: Need special formula for data entry
Assuming you want something more complicated than simple + and - formulas, it isn't clear to me what you want to do.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
I want to print the values before + or minus symbol and after + or - symbol in next 2 columns.
haha, if homework, why should I post, I would have asked my teacher.
If you know the answer, please help. No need to comment showing your highness.
"if homework, why should I post"
This site averages 2 student posts per week, because that's what some students would rather do.
Excel has string handling functions such as Left, Mid, Right for parsing strings. You can use the Find function to look for the ± character.
TTFN (ta ta for now)
I often use custom formatting rather than concatenation - it keeps the cell contents to numeric values that can be used elsewhere.
You posted thread770-420991: Macro to get input box with required values, very similar. No resolution there???
What have you tried
in either of these two threads?
What works or does not work?
Often if you explain what you tried and what results you observed, it can be helpful.
BTW, images are great for admiring. But if you want help, a worksheet is required. I won't waste my time trying to transcribe your picture.
Skip,
glassesJust traded in my OLD subtlety...
for a NUance!tongue
I guess that you could do this with an ordinary formula. No need to use a special one.
Yes, just native Excel functions like, LEFT(), RIGHT(), FIND(), LEN()
For instance, just to get you started, Nominal could be...
=--LEFT($A2,FIND("±",$A2)-1)
...where A2 is the source cell.
Skip,
for a NUance!tongue
Thank you Skipvought, I got some formula for the same.
=LEFT(B13,FIND("±",B13)-1)
=SUBSTITUTE(B13,CONCATENATE(C13,"±"),"")
Thank you very much all for your support.
Ravi
What is
about?
Skip,
for a NUance!tongue
To print value next to plus or minus sign.
> Isn't that what you're starting with?
> Your columns suggest that you need to handle the case where + and - tolerances are different, which means that you need to handle something like mm.mm + pp.pp - nn.nn
But I feel sorry for you, so here's a solution using Named Ranges.
Display	Nominal	Plus tol	Minus tol	max value	min value
20±0.01	20	0.01    	-0.01   	20.01   	19.99
Nominal: =--LEFT(Display,FIND("±",Display)-1)
Plus tol: =--RIGHT(Display,LEN(Display)-FIND("±",Display))
Minus tol: =-RIGHT(Display,LEN(Display)-FIND("±",Display))
max value: =Nominal+Plus_tol
min value: =Nominal+Minus_tol
Skip,
for a NUance!tongue
He's just asking about THIS one thing.
The other stuff is multiple cells, and I have no idea how the requirement will be stated. He's all over the place.
Skip,
for a NUance!tongue
Hi SkipVought,
As I am Design engineer and very new to excel, took the help of this forum.
Thanks for the support and I got solution.
I will continue the next plan converting these formulae to userform by help of colleagues here.
Once again thank you very much eng-tips and supporters.
Ravi.
