Transformer phase shifts
For delta-wye 161-13 kV transformer, I'm not seeing a 30 degree shift between primary and secondary currents. In fact the secondary currents are LEADING the primary by 120 degrees. This is being seen on a SEL 787 relay. At this point the transformer is lightly loaded. Is this correct?
RE: Transformer phase shifts
Bill
"Why not the best?"
Jimmy Carter
