Turn Buckle and Rod Design
Could someone share a good reference procedure on design of turn buckles and rods?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Turn Buckle and Rod Design
Welp, back to the drawing board?
What are the turnbuckles and rods intended to accomplish? You really didn’t say. As Hokie mentioned the/some turnbuckles may not be rated at the same cap’y. as the rods which fit them, and of course, you should limit your design strength to the strength of the weakest link. There are several different grades, strengths and sizes of turnbuckles from different suppliers. And, I certainly wouldn’t buy my turnbuckles from the local big box store if strength was important.
Once you pick the tension rod you can pick the turn buckle as well as end connections from the catalog
So all parts belong to the same 'system'
best regards
Klaus
That may be true for light stuff, but is not typical for structural bracing.
see here for example
http://www.mconnect.eu/en/application/practical-co...
and many others
best regards
Klaus
That company looks like it has a well thought out system, but I imagine it operates primarily in Europe. I don't think that system or similar is typical of other parts of the world.
Anybody else here who would routinely specify these rods? They look good, but I think their application is in high end structures, airport terminals and the like.
http://www.mconnect.eu/images/Downloads/tension_ro...
Dave
Thaidavid
thaidavid40, are you saying you typically use only 20% of the loads specified by the manufacturer or the loads specified in the AISC manual?
it is part of the system...
best regards
Klaus
I'm saying, "20% of the ultimate turnbuckle capacity." Most manufacturers list their "safe working strengths" in the typical online data. If you order from them, they will supply an ultimate (usually tested) strength. Apply the 0.20 resistance factor multiplier to that number.
Dave
Thaidavid
Dik
You said....., “The loading on this system is approx. 20 kips. The system is going in a school gym behind glass curtain walls.” That being the case, you may want to pay some special attention to bldg. drift up at the top, under load, as this relates to the rigidity of any glass and glass curtain wall system. Tie rods allow a fair amount of movement of their upper connection points before they pick up their design load, due to slack take-up, due to geometric and stress/strain length changes and this can have detrimental effects on any rigid cladding system.
