Stable Time Increment
Dear Friends,
I am wondering for two issues in Abaqus Explicit analysis:
1.It would be possible to extract Stable Time Increment (for each element) from *Odb file?
2.The Stable Increment reported in *Sta file is principally employed for the whole elements inside the model; or it is a value just for critical elements?
Thanks in advance,
RE: Stable Time Increment
1. Request History output variable in Step module. DT, Time increment in History output request -> State/Field/User/Time. After analysis, Create xy -> ODB Field output, then select output DT and choose the element you are interested in.
2. Yes, critical element.
thanks in advance
