retained austenite VS ferrite how do you recognize them under microscope
Hello All
I have sample with white phase on it how do I know whether it is retained austenite or ferrite when I put it under microscope?
thank you
RE: retained austenite VS ferrite how do you recognize them under microscope
Microhardness testing.
Specify the alloy, thermal conditions, etchant used to have an idea. Yet as metengr states, microhardness testing can be one of the simplest test.
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
