Aluminium Takeoff in STAAD
while analyzing a structure with aluminium members supported by Steel frame in Staad pro. for the member take off results,i dont find the aluminium take off values instead having only the steel takeoff values.
Help me to take the aluminium takeoff in the staad results.
thanks in advance.
thanks in advance.
RE: Aluminium Takeoff in STAAD
It works the way you mentioned.
Click on the 'Design' Page Control tab on the left of the screen. That displays the various methods avaialble as sub-tabs, the default being the top which is 'Steel'. The forth tab is 'Aluminum'. If you click on that to add the paramaters and commands for the alumminum design, then the dialog on the right will provide aluminium design commands. Click on the 'Commands' button , seelct 'Take Off' and click Add (or assign if you have pre-selected the members you wish to measure). You should find that the command ALUMINUM MEMBER TAKE OFF (member list) will be added to your file when you display it in the editor.
