Export Assosiated Files
Dear all,
i'm have a little problem in understanding the context in the Customer default text. It says:
"Export assosiated files determines whether or not files associated to part files will be exported from the Teamcenter database to a local directory when a part file is saved". So when i deactivate the option i still didn't see any effect of that in the file export that i made.
To begin with, what is actually meant by the assosiated files? and how can i see if the effect when i deactivate the option?
RE: Export Assosiated Files
Exported to the local folder where the part
is exported.
When you chose file export Assembly
On the dialogue that open one of the tabs
Say associated files and there a list
Of files types that also will be exported
with the Assembly part that you export.
