Multiple secondary target points
When using datum targets on a flexible part with a complex shape, there is no limit to the number of primary target points. Can the secondary have more than two target points?
RE: Multiple secondary target points
"In a restrained application, it is permissible to use as many datum targets as necessary to establish the datum features."
Season
Also, there are instances of a secondary datum needing less than two points of contact -- only one point.
John-Paul Belanger
Geometric Learning Systems
