Pressure drop across a Attenuator
I have an attenuator size LXWXH 1x1x1m, having splitters of size 100 mm each at a gap of 100 mm, So in total 50% if the effective opening area, Air flow is at 50,000 CFM, Temperature is 55 Degree C, How do I calculate the pressure drop across the attenuator,
Appreciate your inputs
SEMPER
SEMPER
RE: Pressure drop across a Attenuator
http://iacacoustics.com/pdf/IAC%20Acoustics%20Duct...
Walt
