Controling Layers / bodys
Hello i wonder if anyone could help me or point some directions...
i have this code:
CODE
For Each bodyItem As Body In CType(child.Prototype, Part).Bodies
                    Dim tmpNXObject As NXObject = child.FindOccurrence(bodyItem)
                    If Not tmpNXObject Is Nothing Then
                        componentTagList.Add(CType(tmpNXObject, Body).Tag)
                    End If
                Next
credits: petulf
and i would like to exclude the bodys on layers 50,90,250-255
could anyone point me something ? itryed to record a jounral hiding the layers then adding it to the code but no result :(
NX8.5 - NX9 - NX 10 - NX11
RE: Controling Layers / bodys
Once you have a reference to the body, you can check the .Layer property and take action based on the layer number.
www.nxjournaling.com
Use the layer property of the body object and check if the value is in a list of layers.
CODE --> VB
Dim exclusionLayers As New System.Collections.Generic.List(Of Integer)({50, 90, 250, 251, 252, 253, 254, 255})
    If Not exclusionLayers.Contains(bodyItem.Layer) Then
    End If
  End If
Next
Thanks both :D
i think it worked i will do some more tests if i ecounter problems i will reach u :)
yes its woking :D thank you
in some prts its not doing what its suposed to but i think its because he dont find the linked body prt example:
i have
TOP_PRT
-PRT1 (CONTENTS: SOLID BODY + LINKED garbadge_subprt SOLID BODY)
--garbadge_subprt(CONTENTS: SOLID BODY )
-PRT2 (CONTENTS: SOLID BODY + LINKED garbadge_subprt SOLID BODY)
when the code runs if im missing the garbadge_subprt its returning NXopen error. i will explore it and say something :)
petulf i had to comment a line from ur export code
CODE
tagsList.AddRange(GetBodyTagsInAsm(currentPart.ComponentAssembly.RootComponent))
it was in conflit with what im trying to do.
anyone knows if its possible or could point me something to export a parasolid with another WCS from another file?
example:
TOP_PRT
when i export it will export PRT1/prt2/garbage (separately) with WCS from TOP_PRT
cowski since you are more experienced could you point me something on that matter ?
