Help w/ Multiply a List by Scalar then by Another List
I need assistance in trying to write the formula on the rule sheet for multiplying a list by a scalar and then be another list.
The actual formula is as follows:
Ao = [Sum(Xi * Aoi^1/2]^1/2
where:
Xi is List1
Aoi is List2
I need to take the square root of Aoi, multiply by Xi, and then and then take the quare root of the sum.
-pmover
where:
Xi is List1
Aoi is List2
-pmover
RE: Help w/ Multiply a List by Scalar then by Another List
call blank('@temp)
for i = 1 to length('Xi)
'@temp = 'Xi * sqrt('Aoi)
next i
Ao = sqrt(sum('@temp))
call delete('@temp)
Then list "Ao" as an Output Variable. No Input or Parameter Variables are required.
If you named the function "pfAo" your Rule Sheet would contain the rule: Ao = pfAo()
Let me know if you have any further questions regarding this procedure.
