Recommendations for Rocket Nozzles
I'm part of a group of hobbiests who make ther own model rocket engines. We have been using graphite for nozzles. It is quite expensive and needs to be machined.
I found a material from Contronics in NJ called Rescor 770. It is a 2 part (powder and activator/resin) castable silicon carbide ceramic. It is lower in cost than graphite and moldable at room temperature as well. However, it is still too expensive at about $10 per pound.
Does anyone have a recommendation for a suitable castable ceramic of either tungston or silicone carbide. The material will have to be castable at room temperature, However, post curing at elevated temperatures is OK (hopefully not at kiln levels).
We have tried pourstone concrete anchoring material and it works fairly well. However, it erodes and degrades motor performance. The actual working pressure in an engine can exceed 1000-2000psi.
Tha actual nozzle is 2" in diamter X 2" long and is held in the motor casing by a snap ring around the front face of the nozzle. Combustion gas temeratures can exceed 3500C for periods of 10 seconds or less.
RE: Recommendations for Rocket Nozzles
The combustion gas temperature and the pressure as stated by you may not sustain Silicon carbide type materials.Have you tried glass ceramics.There are machinable glass ceramics where the extent of crystallization can be controlled to give required strength and refractoriness against heat. Other wise the best is boron nitride.It is a new age ceramic having high temperature resistence and strength .However I do not have an idea whether you can cast it.
Hope this is useful to you.
A possible source for the fused silica is Ceradyne Thermo Materials in Scottdale, Georgia. They have a Netshape 900 material that may meet your needs. A source for the alumina fiber castable is Zircar Products in Florida, New York. You read that right, Florida is the town, New York is the state. Good luck with the search and be careful out there.
