Dual Springs Safety Valve
Hi everyone
Recently I saw a safety valve which has dual springs. There is an inner spring and outer spring. I have asked around about the purpose of such construction, unfortunately, I have not received a convincing answer.
Therefore, could someone who has an experience with this kind of valve, explain the use of inner and outer spring? Thanks.
Best regards
Aida
RE: Dual Springs Safety Valve
Either more force without using a large spring or redundancy.
The throttle return springs on cars were dual wound, for safety.
I've seen it done as a way of uprating the set pressure of an existing valve type (albeit a spring regulator rather than a safety valve) while maximising parts commonality with the rest of the range and fitting within the existing physical envelope.
A.
