Thermodynamics of polymer mixture
Hi everybody, i need to do phase equilibrium calculation for polymer mixture. HPS is used to separate super-heated polymer(LLDPE) from gas diluent (isobutene). I think i need to use vapor-solid equilibrium for the mixture, however on the internet there are lots of materials which use vapor-liquid equilibrium for the mixture. which one should be used ?? can someone help ? Thanks in advance.
