Simulation for specific parameters values
Hello dear Forum users.
I'm quite new to NX and this forum helps me big time!
Unfortunately there's some issue that I cannot find solution for. I'm working on parametric model of single surface that is driven by multiple parameters in NX 9. I would like to perform simulations: 101 linear static and 105 linear buckling for many different cases of parameters. I'm not looking after "optimal" solution, I need to know specific results for all defined parameters cases. Those parameters must be integers, for example a=[1,2,3,4], b=[4,5,6,7] which results in 16 different model's configurations. Is there any tool in NX that could solve that problem? Is Global Sensitivity analysis way to go for me? How could I set only integer values of defined parameters?
