Minimum weld clearence or space
thread1452-410755: Minimum Weld clearance
If your material is group I,II,III or IIIA there is no restriction in API 650. But if your material is group IV, V and VI there is 150 mm clearance from the vertical.
As mentioned above can i be informed of a reference of API 650 in which section or para this exemption of material group I, II, III has been discussed in API code?
RE: Minimum weld clearence or space
The "exemption" isn't discussed, there simply isn't any requirement for those groups. See Section 5.8.1.2.
