Spoked wooden wheel with a woof in it
A woof is a colloquial term for a warp. Weavers joke.
So, our living room looks like the daleks have invaded. One of the spinning wheels has a 6mm lateral runout. I don't know whether it is the wooden wheel has developed a warp, or whether the axle is bent. I don't know how the wheel is fixed to the axle, slight amounts of brute force didn't reveal any tendency for the two to separate, or any particular structural problems in the wheel itself.
Any ideas? Apparently it is an excellent wheel, light and tall.
Cheers
Greg Locock
RE: Spoked wooden wheel with a woof in it
Keith Cress
http://www.fusionpoint.be
http://be.linkedin.com/in/fusionpoint
First option would be to do nothing. It's a flywheel primarily. Are you actually spinning yarn on the thing? Do the warp actually affect the outcome?
Where does the relative rotation occur? Between wheel hub and axle, or between the axle and the two uprights?
If you really really want to take the wheel off, I guess that the axle is simply a tight fit. Possibly supplemented by some form of sticky stuff.
Mallet and drift punch will certainly get the axle out.
Then what?
What is the goal? Well intentioned, but inexpert restoration typically reduces the value of antiques. So if the desire is to own a collectible antique with some value, do nothing.
If the value is not important and the goal is to restore it to a precision balanced working machine then go at it.
Did the runout just develop, or has it been there all along? Fabricating a hub accurately centred on spokes inside a wheel would be a challenge for someone using hand tools.
JHG
The warp is not sufficient to throw the drive string, it is purely an aesthetic issue. I'm inclined to take the lazy man's approach, if it ain't broke don't fix it.
Cheers
Greg Locock
With something like you have there - getting it to run true is possibly impossible.
Bill (waross) can probably tell us a steamed wood tale. :)
Keith Cress
First is the axle straight, round, and true?
Are the bearings aligned with the two vertical arms that the wheel rim is sandwiched between ? A out-of-perpendicular plane axle (caused by poor axle shape or poor bearing alignment) will exaggerate the movement of the rim of an out-of-plane wheel)
Is the wheel rim moving side-to-side, or up and down (out of plane mismatch, or out of radial distance mismatch)? The difference will affect how you apply steady force to re-bend the rim + wheel + spokes back to nominal.
How much force (and how much time) do you want to use press the wheel rim back to shape? A static display item, or one not used for spinning thread, will have an different answer than one the operator is forced to look at for hours and hours as the wheel spins in front of her face. A bad wobble could turn a relaxing hobby into an irritating chore in minutes!
(But, as far as the out-of-round woofer, I really don't see any dog caught in the warped wheel ...)
With the wheel in the frame, find the high spots of the wobble (using the the frame posts as a reference) and use wedges between the frame posts and the wheel to push the wheel past flat (as there will be springback when the wedges are removed. Leave the wedges in place for days or weeks. Remove the wedges and check for warp. Repeat as needed.
I think the most likely cause of the wobble is that there has been some movement in the spoke joints. It is unlikely that the axle pin bent, considering how stubby it is.
Yes, that is my current plan. Having checked the other wheels we have to hand this one is only slightly worse than the next worst (two run true, one because it is a synthetic solid wheel, so much for romance).
Cunningly the designer did not use a grooved wheel, but a wide flat land, so the string can run where it likes. The only complication is that it is a double drive, one continuous loop doubled that drives both the flyer and the bobbin.
I can't check the axle without removing it. On further inspection I suspect the mid part of the axle is threaded, so the wheel is clamped between a flat nut and a large threaded washer. The ends of the axle are turned down to go through the journals. My guess is that removing it will also need me to press the journals out. This starts to get into a serious project.
I am loathe to straighten the rim in situ unless I am sure that it is the problem. Once it is out to check the axle then straightening it will be an exercise in heat and weight application, and time.
Yes I do need a dial gauge!
One enormous problem with all these wooden wheels is splitting and general fragility, even though they are less than 30 years old. Just yesterday I dropped a bobbin on a slate floor and it cracked in two.
Cheers
Greg Locock
Cheers
Greg Locock
