Flexible joint on suction and discharge pipe
Under what conditions should flexible joints(Eg. Bellow type) be provided on suction and discharge piping? I have a low lift 30 hp sewage pump application and I am curious to find out whether these are really required as I hardly see these on most of the pump applications I come across.
Thanks in advance
Thanks in advance
RE: Flexible joint on suction and discharge pipe
However, wouldn't you think by not seeing many would suggest something.
