High and Low Roof Condition
I have a condition where the low end of a high roof and the high end of a low roof meet and there is only 12" clearance between the two. If this gap were larger, I would just have both a high beam and a low beam to pick up each roof respectively. The other idea I had was to use a single high beam with a ledger (angle welded to web of beam) to pick up the low roof. This will place some torsion into the beam but given the circumstance I think it is my best option.
What have you all done in a similar situation?
RE: High and Low Roof Condition
Quote (TX)
I like that option. Torsion shouldn't be an issue as the upper and lower diaphragms should create a rectifying couple to limit torsion in the beam. Another perk is that this setup would provide a robust mechanism for transferring diaphragm shear across the step if such transfer is needed. Other setups that I've seen but like less:
1) Low beam and an HSS "fence" on top upon which the upper joists bear.
2) High beam and an HSS fence below for the lower joists to bear.
3) High beam and hung bracket at each low joist for support.
Does a W12 work?
Bottom flange is a great ledger angle substitute
