Phase Current Variation
I have a power monitor connected to the input of a 440VAC 3-phase voltage regulator. The input transformer is a delta configuration with no neutral.  Is it normal to see a difference in the phase current measurements?  I am observing the following:  L1=0.521A, L2=1.561A, L3=1.964A.
What would be the explanation(cause)for this?
Thank you for helping me understand.
RE: Phase Current Variation
With balanced phase voltages, 3ø current imbalance is usually load based.  What is the regulator powering?  Of less importance, is the ‘input transformer’ separate from the regulator?
I need to correct my initial thread entry.
The power monitor is connected to the OUTPUT of a 440VAC 3-phase voltage regulator. The OUTPUT transformer of the regulator is a delta configuration with no neutral.
The regulator OUTPUT is supplying a welding machine's 3 phase tranformer input primary winding whose secondary is providing the necessary voltages for the torch and circuitry of welding machine.  I am observing the different phase curents with the weld machine in an idle state and when it is in a weld state.  Sorry about the confusion.
Have you check for harmonics?
