Reduce Fe in ore
Reduce Fe in ore
Reduce Fe in ore
Seeking help on attempting to reduce the iron content of ore. It's at about 70-95%, trying to reduce it as much as possible. Any help appreciated.
RE: Reduce Fe in ore
You want to REDUCE the iron content of an ore which is 70-95% what, iron? Heck- add some SAND to it!
You need to re-state your question more clearly, with more details, if you would like meaningful help. What kind of ore? Ore of what metal? 70-95% refers to what species or element? What is your target?
Have you read " Iron and Steel Making" by Bashforth, "Making Shaping,Treating of Steels" ?
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
Never mind guys- got it figured. Thanks!
