JOURNAL CODE FOR FONTS
All of our notes are set at LEROY and a height of 2.5 for our standards. However, specific notes we place on some sheets are supposed to be POSTER and 5.0
I want to give people the choice whether to select the notes they wish to change before running the journal, or to run the journal and it would prompt them to select the notes.
I have a journal for a similar situation where I want specific appended text to be added o certain notes and that works great. I cant figure out how to convert this from appended text for dimensions, to changing the font and size of notes.
Help is appreciated.... the appended text journal is attached in case it helps.
RE: JOURNAL CODE FOR FONTS
What version of NX are you running ?
Isn't it time to migrate to the TrueType fonts ?
( The "Unigraphics type" fonts have one (?) benefit and that is the "engrave-ability", due to the single stroke/no fill definition. But apart from that , i don't know.)
Tomas
Suresh
www.technisites.com.au
