NX11 Import Part with Scale Doesn't work properly
Hi Folks
Has anybody imported a part using scale in NX11. I've reported a problem to GTAC back in October 2016 (PR#7862496) which was able to be repeated at Siemens. Yesterday I get email from Software Engineering and they say it "WORKS AS DESIGNED". Well if anyone tries it you'll see it is a two step process... you enter your scale in the box, hit ok...THEN HIT CANCEL. That registers your scale factor.. then you do the command again and continue as normal. problem is if you change scale again you have this two step process. I'm putting this out as a warning to those that use it. I can't fix stupid put i can work around it. HAVE A GREAT DAY!
Brian
