AWS d 1.8 versus d.1.1 accept/reject criteria
my experience with UT examination of structural welds is with AWS D1.1 , I have a client who I have worked for in the past that has a issue that came up on a site , the third party UT examiner rejected a number of full penetration welds based on AWS d1.8 however the project only required the welds meet AWS D1.1 , not being very familiar with 1.8 other than knowing the basic premise, is D1.8 UT accept/reject more restrictive than AWS D1.1 , after being informed of his mistake the third party refuses re-evaluate the welds based on AWS d1.1 he stated no difference in accept/reject between codes . Thanks
RE: AWS d 1.8 versus d.1.1 accept/reject criteria
I would normally provide a better response, but I'm on the road at the moment and do not have access to the two standards you are asking about. My recommendation is to ask the inspection agency to send you a photocopy of the acceptance criteria they are saying is the same so you can compare them.
Several years ago I had a similar situation where a different inspector performed some UT without asking whether the connections were cyclically loaded or not. He assumed they were statically loaded when in fact the design specified cyclic. If your inspector didn't ask and if you didn't specify the nature of the loads, the test results must be suspect.
Best regards - Al
