Where could I find data about testing turbocharged dieselengine?
I have made a mathematical model and I need experimental data to validate it.
I need
- basic engine geometry.
- turbocharher maps or references where to find it.
- intake exaust pipe geometry for 1-d simulation.
- Preasure-time (or crankshaft angle) in the cilinder, intake and exaust pipe(s).
In return I would offer my program and documentation.
I need
RE: Where could I find data about testing turbocharged dieselengine?
http://www.turbofast.com.au/
Has a lot of info on turbos, with links to the major turbo manufactures. For geometery it would really depend on what you are looking for. Like strokes and bores? I have DeskDyno on my system which tells me a lot of that basic information. If you have an idea, let me know and I will look it up and tell you what it says. Hope this helps. I also have TurboCalc, which gives maps and refernce to best matched turbos and injectors and what not. Pretty much anything about turbos is on that program.
