Continue of thread "Brine Maker" or "Brine Saturator" Design Guide
Hello Everyone,
I have searched Brine Maker design guidelines and found the thread http://www.eng-tips.com/viewthread.cfm?qid=225681#...
would really appreciate further information for brine maker sump type, (from truck to sump without pneumatic conveyor)
-Softener is a 3+1x6m3 ion exchange resin, to produce 110m3/h each envelope.
-Brine for regeneration is 10 tonnes of salt per day, (don't know flow rate)
could someone provide further information about sump volume for a desirable stock of salt is 7 days.-
thank you
RE: Continue of thread "Brine Maker" or "Brine Saturator" Design Guide
You need to talk to the local supplier to determine the availabe delivery methods.
You capacity is likely to be too large for a "brinemaker" and you will have to construct something larger.
Salt may be dumped from a truck into an unloading station and either conveyed to a below ground tank or above ground tank.
Salt is conveyed, blown into, or dropped into a below grade concrete tank (saturator tank) from a delivery truck or railcar through an opening at the top of the tank. A 30% brine solution is produced from an underdrain piping system by dissolving a solar grade of sodium chloride (sodium chloride that meets all specifications in ANSI/AWWW Standard B200-98) with water that has undergone softening and cartridge filtration. The brine level in the saturator tank is maintained below the salt, which assures that a 30% brine concentration is maintained (approximate solutibilty of sodium choloride above 50OF is 30%. A level probe system maintains the brine depth. Saturator tank should be sized to hold 1 - 1/2 times the transport volume.
saturator
http://www.goodwater.co.uk/cms/assets/1/pages32-34...
