Define Torque to be applied on stud bolts for on flange connection.
Hello everybody,
Could you please help me to define the torque to be applied on bolts for flange connections. I have several different material (A320 B7/L7 A193 B8) and I would apply 50% of yeld. I shall give evidence to my Client that applied torque is ok, if you can please provide some reference to technical formula.
Thanks for cooperation.
RE: Define Torque to be applied on stud bolts for on flange connection.
Start with ASME PCC-1. It should have all the info you need.
Andrea.Abbo,
Go here:
http://www.wermac.org/bolts/bolts_bolting-torque-t...
Be aware, the column on the left side of the Table is the Bolt Diameter not the nominal pipe size.
Sometimes its possible to do all the right things and still get bad results
What is the specific gasket material you intend to squish between the flanges? THAT material (not the flange itself) is the critical sealing element.
AS a guide, use the information given by one or more of the gasket manufacturers - Flexitallic, Lamons, etc. I've used them for years, and they seem to be conservative enough for most applications.
