Need water Flow Calculation for a punctured pipe of perfect 15mm dia.
Dear Friends i want to make a calculation for discharge rate of 50mm dia pipe punched perfect of 15mm dia Pipe at the bottom of which is installed horizontally in the roof of a room. where pressure is maintained in constant of 7kg with the help of a makeup pump with pressure drop sensor.
RE: Need water Flow Calculation for a punctured pipe of perfect 15mm dia.
I suggest an orifice calc + branch flow loss using the smaller of the diameters.
I used to count sand. Now I don't count at all.
Sounds like a homework problem. What does your professor say about it?
Also... since when was "kg" a unit of pressure?
