sketch dimension scale in draft
Hi All,
I have several sketch lines in the drafting with dimension. my scale of drafting is 40:1, rather than 1:1. When I put dimension between sketch lines or between sketch line and draft line, the dimensions do NOT the "real" dimension. They are scaled by 40X. How can I put the real dimension between sketch lines in the scaled drafting? Thank you.
RE: sketch dimension scale in draft
Can you provide an example of this ?
( create a new example if confidential data.)
NX version ?
Tomas
